Subject: Revised Wheel Drive Shaft Outer Joint and Seal Replacement and Wheel Drive Shaft Inner Joint and Seal Replacement Procedures
Number: 03-04-95-001 - (01/09/2003)
Models: 2001-2003 Chevrolet Corvette
This bulletin is being issued to revise the Wheel Drive Shaft Outer Joint and Seal Replacement and Wheel Drive Shaft Inner Joint and Seal Replacement procedures in the Rear Wheel Drive Shafts sub-section of the Service Manual. Please replace the current information in the Service Manual with the following information.
The following information has been updated within SI. If you are using a paper version of this Service Manual, please make a reference to this bulletin on the affected page.
Important
Special tool J 46588 is a NEW tool.
Because of a mid-year change in 2001, the large diameter clamp is now a low profile design, instead of the Omega clamp design. The new design clamp requires the use of Special Tool J 46588 to install. The following steps effect 2001 model year vehicles with the second design clamp and all 2002 and future model year vehicles.
The following steps should be used when installing the clamp.
Align the following items while latching:
Using the J 46588 (1), latch the large seal retaining clamp. Ensure that the latching tangs are fully engaged in the large seal clamp band.
Article ID: 446
Created: July 23, 2014
Last Updated: July 23, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2003-corvette-service-manual-update-revised-wheel-drive-shaft-outer-joint-and-seal-replacement-and-wheel-drive-shaft-inner-joint-and-seal-replacement-procedures-446.html
