Number: 01-05-25-004A
Subject: Yellow Traction Control/Handling Lamp On and Driver Info Center Displays Service Hndlg (Handling) (repair/Reprogram ABS Module)
Model Year: 2001-2002 Chevrolet Corvette Built Prior to VIN Breakpoint 25106536
This bulletin is being revised to add an additional model year and revise the text. Please discard Corporate Bulletin Number 01-05-25-004 (Section -- 05 Brakes).
Condition
Some customers may comment that the "Yellow" message, "Service Traction Active Handling", is illuminated on the Driver Information Center.
The technician may find chassis DTC C1288 -- Vehicle Stability Enhancement System (VSES) Steering Wheel Sensor Phase A and B. When this code is set, the VSES is turned off; ABS and TCS remain operational.
Correction
Verify the Techline equipment has been updated with TIS software 12 or newer. If it has not been updated, do so now. This software was broadcast to dealerships on 11/13/01. Disc Number 12 will be mailed November 14, 2001.
Article ID: 450
Created: July 23, 2014
Last Updated: July 23, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2001-2002-corvette-service-bulletin-yellow-traction-control-handling-lamp-on-and-driver-info-center-displays-service-hndlg-450.html
