If you raise the rear portion of the canvas top, you will see the strut rods on each side which can be adjusted.
Each rod has a 13mm adjusting nut and a 15mm locking nut. Loosen this locking nut and slightly turn the adjusting nut a little at a time. Each time you turn the nut, raise the top and check for proper clearance. The amount of clearance should be equivalent to the thickness of a credit card.
Article ID: 458
Created: July 24, 2014
Last Updated: July 24, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-2003-corvette-convertible-prevention-of-convertible-top-from-rubbing-against-the-paint-behind-the-plastic-strip-458.html
