1997 Corvette: Service Bulletin: Water Drips into Rear Compartment After Hatch/Glass Has Been Opened
Subject: Water Drips into Rear Compartment After Hatch/Glass Has Been Opened (Modify Weatherstrip)
Number: 73-10-55
Models: 1997 Chevrolet Corvette
Condition: Some owners may comment that water drips into the rear compartment after the hatch glass has been opened.
Correction: Modify weatherstrip following instructions below.
PROCEDURE:
- Pull down weatherstrip to gain access to the end of the black close out weatherstrip (see Figure 1, top view). With a utility knife, cut the close out weatherstrip so there is a 2 MM (3/16 in.) overhang of the weatherstrip to its mounting surface (See Figure 1, top view)
- With weatherstrip pulled down, measure 18 MM (3/4 in.) from end of weatherstrip and remove shaded area from weatherstrip (see Figure 1, bottom view). Reinstall weatherstrip on hatch.
WARRANTY INFORMATION:
For vehicles repaired warranty, use:
Labor Operation Number: C1280 Labor Operation Time: 0.3 HR
Article ID: 464
Created: July 24, 2014
Last Updated: July 24, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-corvette-service-bulletin-water-drips-into-rear-compartment-after-hatch-glass-has-been-opened-464.html
