Subject: Loose or Missing Headlamp Door Bezel Plug (Install New Bezels and Plugs)
Number: 99-08-42-005
Models: 1997-99 Chevrolet Corvette
This bulletin is being revised to add the 1999 model year, update part numbers, service procedures, labor operations and labor times. Please discard Corporate Bulletin Number 83-82-07 (Section 8 - Chassis/Body Electrical)
Condition
Some customers may comment that the plastic plug that covers the headlamp aiming adjustment screw on the inboard side of the headlamp door bezel is loose or missing.
Correction
Two different size plugs have been used in production. Early production 1997 vehicles used a plug with a diameter of 24 mm (15/16 in), while later 1997 vehicles and all 1998 and 1999 vehicles use a larger 54 mm (2 1/8 in) diameter plug. Both size plugs have been replaced by a new design plug and, therefore, will no longer be available.
Using the following service procedure, replace both the left and right headlamp bezels with the new design bezels that have a large NOTCHED hole. The notched hole is required for installing a new design NOTCHED plug.
Service Parts Information
Part Number |
Description |
Pkg. Qty. |
Qty. Required Per Vehicle |
10435410 |
Plug |
2 |
2 (1 Per Bezel) |
10435411 |
Bezel, Headlamp - Left |
1 |
1 |
10435412 |
Bezel, Headlamp - Right |
1 |
1 |
Article ID: 467
Created: July 24, 2014
Last Updated: July 24, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1999-corvette-service-bulletin-loose-or-missing-headlamp-door-bezel-plug-467.html
