1997 - 1998 Corvette: Service Bulletin: Waterleak Above Door Glass (Reseal Blowout Clip)
Subject: WATERLEAK ABOVE DOOR GLASS (RESEAL BLOWOUT CLIP)
Number: 83-15-08
Models: 1997-1998 Chevrolet Corvette Coupe and 1998 Chevrolet Corvette Convertible
Condition: SOME OWNERS MAY COMMENT ON A WATERLEAK ABOVE THE DOOR GLASS, AROUND THE BLOW-OUT CLIP.
Correction:
- REMOVE THE WEATHERSTRIP.
- REMOVE RUN CHANNEL.
- REMOVE BLOW-OUT CLIP.
- APPLY A SMALL BEAD OF BEDDING AND GLAZING COMPOUND TO THE SIDE RAIL OR COUPE (SEE FIGURE 1 (COUPE) OR FIGURE 2 (CONVERTIBLE); THEN REINSTALL THE BLOW-OUT CLIP.
- SET BLOW-OUT CLIP IN PLACE AND APPLY A SMALL BEAD OF BEDDING AND GLAZING COMPOUND OVER THE TOP OF THE BLOW-OUT CLIP (SEE FIGURE 1 (COUPE) OR FIGURE 2 (CONVERTIBLE).
IMPORTANT:
PUSH OUTWARD ON THE RETAINER DURING INSTALLATION.
- RESEAL THE FRONT AND REAR CORNERS ON THE COUPE AND THE FRONT CORNER OF THE CONVERTIBLE WITH WEATHERSTRIP ADHESIVE; 3M(R) P/N 08011, OR EQUIVALENT (SEE FIGURE 3).
- REINSTALL WEATHERSTRIP.
PARTS INFORMATION:
10252849 - COUPE/LH - RETAINER - FRONT WINDOW
10252850 - COUPE/RH - RETAINER - FRONT WINDOW
10252853 - CONVERTIBLE/LH - RETAINER - FRONT WINDOW
10252854 - CONVERTIBLE/RH - RETAINER - FRONT WINDOW
Figure 1 ![](/tech/knowledgebase/images/tech/83-15-08a.gif)
Figure 2 ![](/tech/knowledgebase/images/tech/83-15-08b.gif)
Figure 3 ![](/tech/knowledgebase/images/tech/83-15-08c.gif)
Article ID: 469
Created: July 24, 2014
Last Updated: July 24, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-bulletin-waterleak-above-door-glass-reseal-blowout-clip-469.html
