Subject: ENG. TICKING NOISE-CHK. TORQUE ON EXH. MAN HEAT SHIELD BOLTS
Model and Year: 1992 CORVETTE W/ LT1 ENGINE
Source: Chevrolet Product Emission Campaign
Bulletin Number: 92-301-6A - (09/28/1992)
CONDITION:
Some owners of 1992 Corvettes with the LT1 (VIN P 5.7L V8) engine may comment of an engine ticking noise that may sound like a piston type noise.
CAUSE:
Bolts holding the exhaust manifold heat shield to the exhaust manifold may be backing out causing a slight exhaust leak.
CORRECTION:
Before attempting any repairs, check the torque on the three (3) exhaust manifold heat shield bolts and tighten if necessary. Recommended torque is 8-12 N.m (72-108 lb. in.). If bolt is missing, replace with P/N 11508567.
Article ID: 514
Created: July 26, 2014
Last Updated: July 26, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-engine-ticking-noise-check-exhaust-manifold-bolts-514.html
