Subject: Excessive Engine Oil Consumption/Rough Idle (Replace Intake Gaskets)
Model and Year:
1994 BUICK ROADMASTER
1994 CADILLAC FLEETWOOD
1994 CHEVROLET CAMARO, CAPRICE, CORVETTE AND IMPALA SS
1994 PONTIAC FIREBIRD WITH 4.3L OR 5.7L ENGINE (VINS W, P - RPOS L99, LT1)
Bulletin Number: 47-61-11
REVISION: 05/11/94
THIS BULLETIN HAS BEEN REVISED TO ADD VIN BREAKPOINTS UNDER THE "CONDITION" SECTION
CONDITION:
SOME OWNERS MAY COMMENT ON EXCESSIVE OIL CONSUMPTION OR A ROUGH IDLE COLD. VEHICLES BUILT BEFORE THE FOLLOWING VIN BREAKPOINTS ARE AFFECTED.
DIVISION SERIES ENGINE VIN BREAKPOINT
CHEVROLET B 5.7L (LT1) RR157820
CHEVROLET B 4.3L (L99) RR158931
CHEVROLET Y 5.7L (LT1) R5114284
CHEVROLET F 5.7L (LT1) R2183941
BUICK B 5.7L (LT1) RR423604
PONTIAC F 5.7L (LT1) R2235066
CADILLAC D 5.7L (LT1) RR722213
CAUSE:
POSSIBLE DELAMINATED INTAKE MANIFOLD SIDE GASKETS.
CORRECTION:
TO DETERMINE IF THE INTAKE MANIFOLD GASKETS ARE DELAMINATED, PERFORM THE FOLLOWING DIAGNOSTIC PROCEDURE:
1. WITH THE ENGINE RUNNING, REMOVE THE OIL FILL CAP AND LOOK FOR ANY NOTICEABLE CHANGE IN ENGINE SPEED.
2. IF AN ENGINE SPEED CHANGE IS NOTED, THE INTAKE GASKETS ARE PROBABLY DELAMINATED.
3. REPLACE THE INTAKE GASKETS WITH THE NEW DESIGN GASKETS.
PARTS INFORMATION:
DESCRIPTION PART NUMBER
INTAKE MANIFOLD GASKET KIT 12524653
PARTS ARE CURRENTLY AVAILABLE FROM GMSPO.
Article ID: 519
Created: July 26, 2014
Last Updated: July 26, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-corvette-service-bulletin-excessive-engine-oil-consumption-rough-idle-519.html
