Subject: PRODUCT CAMPAIGN 92C08 - OIL LEAK AT OIL FILTER
Model and Year: 1992 CHEVROLET CORVETTE
Bulletin Number: 92C08 - (06/15/1992)
TO: All Chevrolet Dealers
BULLETIN REPRINT
This bulletin was originally sent as a DCS bulletin (Administrative Message 01-358) to all dealers on October 10, 1991. The DCS bulletin can now be discarded and this bulletin retained in its place.
General Motors has determined that certain 1992 Chevrolet Corvettes with LT1 engines may develop an oil leak at the oil filter area.
To prevent this condition, dealers are to install washers under the oil filter adapter bolts.
Owners of vehicles involved in this campaign are being contacted by the Chevrolet Customer Assistance Center (CAC) on a branch-by-branch basis in conjunction with Product Emission Campaign 92C11. Refer to 92C11 for details.
VEHICLES INVOLVED
Involved are certain 1992 Chevrolet Corvettes with LT1 engines built within the following VIN breakpoints:
1992 Y-Car Bowling Green "5" N5100001 N5102614
THE INVOLVED VEHICLE LISTINGS BEING PROVIDED FOR 92C08 WILL CONTAIN ALL VEHICLES WHICH REQUIRE CAMPAIGN ACTION AT THE TIME THE DCS BULLETIN WAS SENT OUT IN OCTOBER, 1991. NOTE THAT SOME OF THESE VEHICLES HAVE BEEN REPAIRED SINCE THE DCS BULLETIN WAS SENT TO DEALERS. THESE VEHICLES DO NOT REQUIRE FURTHER OIL FILTER ADAPTER CAMPAIGN ACTION BUT MAY REQUIRE CAMPAIGN ACTION UNDER CAMPAIGNS 92C10 (LOWER TRIM PANEL/BRAKE PEDAL INTERFERENCE) AND/OR 92C11 (OPTI-SPARK DISTRIBUTOR). DEALERS CAN VERIFY CAMPAIGN STATUS BY USING VISS.
Involved vehicle have been identified by Vehicle Identification Number Computer Listings. Computer listings contain the complete Vehicle Identification Number, owner name and address data, and. are furnished to involved dealers with the campaign bulletin.
OWNER NOTIFICATION
In conjunction with Product Emission Campaign 92C11 (Opti-Spark Distributor) and Product Campaign 92C10 (Lower Trim Panel/Brake Pedal Interference), owners of vehicles involved are being contacted by the Chevrolet Customer Assistance Center (CAC). Dealers will be notified by DCS when owner contacts by CAC will begin in their branch. Owner letters will also be sent after a CAC contact has been attempted by CAC within each branch (see copy of owner letter included with this bulletin).
Dealers are to service all vehiclEs subject to this campaign at no charge to owners, regardless of mileage, age of vehicle, or ownership, from this time forward.
Whenever a vehicle sub.ect to this campaign is taken into your new or used vehicle inventory, or it is in your dealership for service in tha future, you should take the steps necessury to be sure the campaign correction has been made before reselling or releasing the vehicle.
Owners of vehicles recently sold from your new vehicle inventory are to be contacted by the dealer according to DCS instructions, and arrangements made to make the required correction according to instructions contained in this bulletin.
PARTS INFORMATION
Parts required to complete this campaign are to be obtained from General Motors Service Parts Operations (GMSPO). To ensure these parts will be obtained as soon as possible, they should be ordered from GMSPO on a "C.I.O." order with no special instruction code, but on an advise code (2).
Part Number Description Quantity
00120393 Washer 2
25010908 Oil Filter (PF51) 1
SERVICE PROCEDURE
1. Inspect bottom side of center console cover near label for orange dot.
If orange dot is present, no further action is required. Proceed to stop 14.
If no orange dot is present, vehicle requires washers under the oil filter adapter bolts. Proceed to step 2.
2. Remove oil filter.
3. Remove forward adapter bolt.
4. Add washer (PIN 00120393) under bolt head.
5. Reinstall bolt with washer and tighten, but do not torque at this time.
6. Remove rearward adapter bolt.
7. Add washer (PIN 00120393) under bolt head.
8. Reinstall bolt with washer and tighten.
9. Torque both bolts to 14-19 lb. ft.
10. Install new filter PF51 (PIN 25010908) and tighten 3/4 to 1 full turn after initial seal contact.
11. Add new (synthetic) oil as required.
12. Run engine and check for leaks.
13. If leaks are found, replace gasket and seal.
14. Install campaign identification Label.
CAMPAIGN IDENTIFICATION LABEL
Each vehicle corrected in accordance with the instructions outlined in this Product Campaign Bulletin will require a "Campaign Identification Label." Each label provides spaces to include the campaign number and the five (5) digit dealer code of the dealer performing the campaign service. This information may be inserted with a typewriter or a ball point pen.
Each "Campaign Identification Label" is to be located on the radiator core support in an area which will be visible when the vehicle is brought in for periodic servicing by the owner. Additional "Campaign Identification Label can be obtained from DAC.
CLAIM INFORMATION
* *** REPAIR PERFORMED PC FAILED PARTS CC-FC LABOR LAB OTH NET PART # ALLOW OP HRS HRS AMT
Inspect - Orange Dot Present - No SK-00 V7130 0.2 0.1 Action Required
Inspect - No OrangE Dot Present - Add 3 25010908 SK-00 V7131 0.6 0.1 $#.## washers And Install New Oil Filter
*Campaign Administrative Allowance.
**The "Parts Allowance" should be the sum total of the current GMSPO Dealer Net price plus 30% of all parts required for the repair.
***The $#.## identified in the "Net Amount" column should be submitted as the cost plus 30% for 1 quart of engine oil (synthetic) or appropriate substitution - Mobil 1 used in conjunction with V7131.
Refer to the Chevrolet Claims Processing manual for details an Product Campaign claim Submission.
Article ID: 523
Created: July 26, 2014
Last Updated: July 26, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-recall-oil-leak-at-oil-filter-523.html
