Subject: TAIL PIPE SMOKE ON START-UP (INSTALL NEW VALVE SEAL KIT)
Model and Year:
1987-91 CAPRICE, CAMARO AND CORVETTE WITH 5.0L AND 5.7L ENGINES
1987-91 C/K, RN, G AND P TRUCKS WITH 5.0L AND 5.7L ENGINES
Bulletin Number: 91-449-6A - (11/12/1991)
THIS BULLETIN CANCELS AND SUPERSEDES DEALER SERVICE BULLETIN NO. 89-314-6, DATED JULY 1990 AND 90-300-6A, DATED JULY 1990. THE CAUSE AND CORRECTION HAVE BEEN REVISED. ALL COPIES OF 89-314-6 AND 90-300-6A SHOULD BE DISCARDED.
CONDITION:
Some owners of the above vehicles may comment on a puff of blue or bluish white tailpipe smoke on startup.
CAUSE:
Oil leaking past valve stem seals and being deposited on exhaust valve(s).
CORRECTION:
A new valve stem seal kit (P/N 12511890) has been released to address this concern. The kit incorporates a new umbrella seal with a "viton" insert for the exhaust valve stem.
Use applicable labor operations and times.
Article ID: 536
Created: July 28, 2014
Last Updated: July 28, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-1991-corvette-service-bulletin-tail-pipe-smoke-on-startup-536.html
