Bulletin Number: 53-10-17
Issued: 24-May-1995
Subject: Door Glass Scratching (Replace Outer Seal in Addition to Glass)
Models: 1994-95 Chevrolet Corvette
1994 VIN Breakpoints (Condition Start) - R5121349
1995 VIN Breakpoints (Condition Start) - S5111420
And all 1994 and 1995 ZR1 Models
Condition:
Some owners of the above vehicles may comment about scratches on door glass (depending on a number of factors including cleanliness, amount of glass cycles, etc.).
Correction:
When replacing the door glass for this condition on the above vehicles under warranty, also replace the outer seal strip. New seal strips are available from GMSPO under the following part numbers:
P/N | DESCRIPTION |
10245645 | Seal Strip (Left Side) |
10245646 | Seal Strip (Right Side) |
Important: When removing reivets, care should be taken to capture all loose pieces to prevent rattles.
Part Information: Parts are expected to be available on 5/22/95 from GMSPO.
Article ID: 55
Created: July 2, 2014
Last Updated: July 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html
