Subject: Engine Miss/Poor Driveability Symptoms (Install Opti-Spark (ABITS) Distributor Assembly Service Kit)
Model and Year:
1994-96 Buick Roadmaster
1994-96 Cadillac Fleetwood
1992-96 Chevrolet Corvette
1993-97 Chevrolet Camaro
1994-96 Chevrolet Caprice
1993-97 Pontiac Firebird/Trans Am
with 4.3L or 5.7L Engines (VINs W, P, 5 -- RPOs L99, LT1, LT4)
Bulletin Number: 87-65-27
THIS BULLETIN CANCELS AND SUPERSEDES DEALER SERVICE BULLETIN NO. 90-416-8E, DATED APRIL 1991. WARRANTY INFORMATION HAS BEEN ADDED. ALL COPIES OF 90-416-8E SHOULD BE DISCARDED.
CONDITION:
Some vehicles with the above engines and equipped with the Opti-Spark (ABITS) ignition system may exhibit an engine miss and/or poor driveability symptoms.
CAUSE:
The (ABITS) cap and the rotor may show carbon tracking, cracking, or water intrusion which can cause an engine miss and/or poor driveability symptoms.
CORRECTION:
Perform strategy-based diagnosis. If it is determined that the ABITS cap and/or rotor is the source of the concern, then a service kit may be now implemented instead of a complete ABITS assembly.
PARTS INFORMATION:
There are two (2) variations of Opti-Spark Distributors. It will be mandatory to identify which type is to be serviced for proper parts procurement.
Distributor |
P/N |
Application |
Kit Contents |
Opti-Spark I (Spline Drive) (No Vent) |
10457735 |
92-94 Y 93-94 F |
Distributor cap, rotor, screws, and washers |
Opti-Spark II (Pin Drive) (Positive Vent) |
10457293 |
94-96 B,D 95-96 Y 95-97 F |
Distributor cap, rotor, cover, screws and washers |
Important
It is necessary to use tool J 39997 (or the equivalent) for the distributor cap screws and tool J 39998 (or the equivalent) for the rotor screws.
Article ID: 555
Created: July 28, 2014
Last Updated: July 28, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1996-corvette-service-bulletin-engine-miss-poor-driveability-symptoms-555.html
