Subject: DELAYED ACCESSORY BUS (DAB) SERVICE INFORMATION
Model and Year:1991 CORVETTE
Bulletin Number: 91-115-8B - (01/15/1991)
The 1991 Corvette is equipped with a Delayed Accessory Bus (DAB) which allows operation of the power windows and audio system for 15 minutes after the ignition is turned off. This owner convenience feature is cancelled when the driver’s door is opened.
No attempt should be made to override this system.
Operation of the DAB is covered in the 1991 Corvette Owner’s Manual and Service Manual.
Article ID: 558
Created: July 28, 2014
Last Updated: July 28, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-delayed-accessory-bus-service-information-558.html
