Subject: INFLATABLE RESTRAINT INDICATOR LAMP STAYS ON
Model and Year: 1990 Y CAR
Bulletin Number: 90-98-0A - (01/03/1990)
CONDITION: The "INFL REST" indicator lamp may stay lit after the 5 second (ignition on) bulb check. This condition may occur right after the vehicle has been worked on for other reasons, such as cluster or steering column repairs.
CAUSE: If the ignition is turned on while any component of the SIR (Supplemental Inflatable Restraint) system is disconnected, or the cluster fuse feeding the indicator lamp circuit is blown, a malfunction code will be stored in the DERM (Diagnostic Energy Reserve Module).
Components that will set codes if disconnected with the ignition on are:
- Driver Information Center (DIC) (Code 42 - Indicator Lamp; Open Circuit)
- Steering column SIR connector (Code 35 - Inflator Squib; Open Circuit)
- Front crash sensors (LH & RH) (Codes 15 or 25 - Front Sensor; Open Circuit)
CORRECTION: Clear malfunction codes from the DERM using the following procedure:
1. Turn ignition "OFF". 2. Ground ALDL terminal ’K". 3. Turn ignition "ON". 4. Wait for fault codes to begin flashing (approx. 5 seconds). When the codes begin flashing, unground ALDL terminal "K" for 3 seconds +/- 1/2 second. 5. After ungrounding ALDL terminal "K" as described in step 4 above, ground it again for 3 seconds +/- 1/2 second.
6. Unground ALDL terminal "K, and wait 10 seconds. Before turning ignition off, verify that Code 12 is the only code being flashed. If not, codes have not been properly cleared. Begin clearing procedure again starting with Step 1.
Article ID: 564
Created: July 28, 2014
Last Updated: July 28, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-inflatable-restraint-indicator-lamp-stays-on-564.html
