Model Year: 1990 w/ L98 or LT5 Engine
Subject: Product Campaign 90C07 Instrument Panel Wire Abrasion
Source: Chevrolet Dealer Product Campaign Bulletin
Number: 90C07
Section: 8C
Date: January, 1990
General Motors has determined that certain 1990 Chevrolet Corvette model vehicles with L98 or LT5 engines may experience instrument panel wires rubbing on the hood release cable bracket causing abrasion of the instrument panel wiring. If this condition continues to exist, the instrument panel wiring may wear through its covering and ground itself on the hood release cable bracket causing a short in the vehicle’s electrical system and an inoperable vehicle engine.
In order to prevent the possibility of this condition occurring, dealers should apply 3M Brand, or equivalent, Electrical Moisture Sealant Tape to the instrument panel wiring and hood release cable bracket, thus protecting the instrument panel wires from abrasion. Additionally, instrument panel wiring which shows signs of abrasion should be repaired.
VEHICLES INVOLVED
Involved are certain 1990 Chevrolet Corvette model vehicles with L98 or LT5 engines built within the following VIN breakpoints:
MODEL/YEAR | PLANT | FROM | THROUGH |
Y 1990 | Bowling Green | L5100001 | L5103172 |
Y 1990 | Bowling Green | L5100001 | L5800227 |
Service Procedure
CAMPAIGN IDENTIFICATION LABEL
Each vehicle corrected in accordance with the instructions outlined in this bulletin will require a "Campaign Identification Label". Each label provides a space to include the five (5) digit dealer code of the dealer performing the campaign service. This information may be inserted with a typewrite or a ball point pen.
Each "Campaign Identification Label" is to be located on the radiator core support in an area which will be visible when the vehicle is brought in for periodic servicing by the owner.
Apply "Campaign Identification Label" only on a clean dry surface.
(Notification Used By Chevrolet Motor Division)
Dear Chevrolet Corvette ZR1 Owner:
This notice is sent to inform you that Chevrolet Motor Division is conducting a recall campaign that includes your vehicle.
General Motors has determined that certain 1990 Chevrolet Corvette ZR1 model vehicles may experience instrument panel wires rubbing on the hood release cable bracket causing abrasion of the instrument panel wiring. If this condition continues to exist, the instrument panel wiring may wear through its covering and ground itself on the electrical system and an inoperable vehicle engine.
To prevent the possibility of this condition occurring, protective electrical tape will be applied to the instrument panel wiring and hood release cable bracket, thus protecting the instrument panel wires from abrasion. Additionally, instrument panel wiring which shows signs of abrasion will be repaired. This service will be performed for at no charge.
Your authorized Chevrolet Corvette ZR1 dealer will be contacting you soon to arrange a service date if it has not already done so. Instructions for making the correction have been sent to your dealer. Your dealer can inform you as to how much time will be needed to schedule, process and repair your vehicle.
The enclosed owner reply card identifies your vehicle. Presentation of this card to your dealer will assist in making the necessary correction in the shortest possible time. if you have sold or traded your vehicle, please let us know by completing the postage paid reply card and returning it to us.
We are sorry to cause you this inconvenience; however, we have taken this action in the interest of your continued satisfaction with our products.
Article ID: 565
Created: July 28, 2014
Last Updated: July 28, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-product-campaign-90c07-instrument-panel-wire-abrasion-565.html
