Subject: High Output Ignition Coil Replacement
Model and Year: 1985 L69 Camaro and Monte Carlo, 1985 LB9 Camaro and 1985 L98 Corvette
Bulletin Number: 85-93 - June, 1985
Some 1985 Camaro, Monte Carlo and Corvettes with high output ignition coils may exhibit driveability problems ranging from hesitations, sags, and stumbles to complete ignition cut-out. These conditions my be caused by extended exposure to high temperatures.
Should any vehicle/engine combination stated above experience the described driveability conditions and normal service procedures (See Service Manual) do not correct the conditions, the following steps are to be taken to prevent future reoccurrence:
Model Year | Vehicle Model | Engine RPO | Replacement Coil | Replacement Module |
1985 | Camaro, Monte Carlo | L69 | 1985473 | 1976908 |
1985 | Camaro | LB9 | 1985473 | 1976908 |
1985 | Corvette | L98 | 1985474 | 1976908 |
FOR 1985 ONLY
Usage | Replace With |
Camaro With L69 and NA5 | 14086583 |
Camaro With L69 and NB2 | 14086585 |
Camaro With LB9 and NA5 | 14086587 |
Camaro With LB9 and NB2 | 14086589 |
Monte Carlo with L69 and NA5 | 14086584 |
Monte Carlo with L69 and NB2 | 14086586 |
Corvette with L98 and NA5 Less NN5 | 14086591 |
Corvette with L98 and NA5 With NN5 | 14086592 |
Corvette with L98 and NM8 | 14086593 |
Article ID: 578
Created: July 28, 2014
Last Updated: July 28, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-corvette-service-bulletin-high-output-ignition-coil-replacement-578.html
