1986 - 1991 Corvette: Service Bulletin: Information on ABS Noise - Self Test
Subject: INFO ON ABS NOISE - SELF TEST NORMAL AFTER IGNITION CYCLE
Model and Year:1989-91 CAPRICE, 1986-91 CORVETTE, 1990-91 WL VAN, 1991 S/T TRUCK (4-DOOR ONLY)
Bulletin Number: 91-241-5 - (02/01/1991)
All anti-lock brake systems (ABS) perform a self-test called initialization during acceleration after each ignition switch cycle.
During this test, the modulator exercises valves/solenoids/motors as the system monitors all inputs and outputs. This test is initiated at a relatively low speed so the ABS can be deactivated in the event there is an abnormal condition detected. Depending on the application, initialization occurs at different speeds, (typically between 0-8 MPH) and will vary in intensity.
As it is possible to hear and feel the initialization cycle, some customers may comment about it. Initialization is a normal condition, therefore, repair should not be attempted.
Article ID: 641
Created: July 31, 2014
Last Updated: July 31, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-information-on-abs-noise-self-test-641.html
