Subject: Right Door Glass Binds, Insufficient Travel, Unable to Contact Weatherstrips
Model and Year: 1993 Corvette
Source: Chevrolet Dealer Sevice Bulletin
Bulletin Number: 93-192-10, Section 10
Date: May 1993
Corporate Bulletin No: 331022
ASE No: B1
CONDITION:
Right door glass that binds, won’t travel to full up position and presents difficulty in sealing to all weather strip surfaces on early build Corvettes with date codes of TA-3 on door glass as indicated in the illustration.
CAUSE:
Glass has incorrect contour.
CORRECTION:
If the door glass has the date code of TA-3 as shown in the illustration, REPLACE THE RIGHT DOOR GLASS ONLY using the procedure found in the body portion of the Service Manual.
NOTE: Only glass with the date code of TA-3 has this condition. Do not replace the left door glass or glass with other date codes for this condition.
NOTE: Due to an in-plant modification, some vehicles with VIN’s between P5103330 and P5103622 may have right side glass that still does not track properly after glass replacement. These vehicles may require replacement of the right door window regulator in addition to the door glass.
Article ID: 647
Created: July 31, 2014
Last Updated: July 31, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-right-door-glass-binds-insufficient-travel-unable-to-contact-weatherstrips-647.html
