Subject: ENGINE COOLANT USAGE ANTI-FREEZE SPECS CHANGE
Model and Year: 1982-1983 Vehicles
Bulletin Number: 83-I-26 - (01/17/1983)
Chevrolet Motor Division has in past model years recommended use of ethylene glycol base anti-freeze that meets GM Specification 1899-M. This recommendation has changed for 1982 and 1983 vehicles which are factory filled with coolant which meets GM 1825-M specifications. It is required that any additions of coolant to these vehicles be done with GM 1825-M. This change was necessary due to the use of aluminum components on some engines which required a different formulation of anti-freeze to prevent corrosion. This anti-freeze is available from WDDGM in gallons and drums as P/N 1052753 and P/N 1052754.
This new coolant may be added to systems which contain anti-freeze meeting the GM 1899-M specifications with no adverse effect, but it is recommended that when a complete draining of a cooling system is performed such as for engine repair, that it be refilled with one source rather than mixing old anti-freeze with new as there may be slight differences in their chemical properties that could affect their overall performance.
Procedures for mixing anti-freeze to water to obtain the required protection level are unchanged.
Article ID: 675
Created: August 1, 2014
Last Updated: August 1, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html
