1969 - 1970 Corvette: Service Bulletin: Odometer Failures
Subject: Odometer Failures
Model and Year: 1969-70 Chevrolet
Bulletin Number: 70-T-27, Section XII
Date: April 30, 1970
TO:  ALL CHEVROLET DEALERS
Some owners of 1969 or 1970 Chevrolets who operate their vehicles in extremely dusty areas may experience early odometer failures due to dust entering into the cluster which may settle on the transfer cogs and cause them to bind.
If odometer failures caused by dirt entry occur, an odometer kit with a dust shield should be installed.  This kit, Part No. 6496557, is available through United Motor Service for all 1969 and 1970 odometer replacements.  It includes the odometer, the dust shield and an instruction sheet.
IMPORTANT:  To comply with some local laws, the replaced odometer must be set to the same mileage as the actual mileage on the vehicle.
Chevrolet Motor Division
General Motors Corporation
Article ID: 685
Created: August 1, 2014
Last Updated: August 1, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-odometer-failures-685.html
