1974 Corvette: Service News: Removal of Corvette Front Speakers
Subject: Shop Manual Procedure Revised - Removal of Corvette Front Speakers 1974 Models
Model and Year: 1974 Corvette
Bulletin Number: Volume 45, November 1973, Number 11
The front speaker removal procedure found on page 15-8 of the 1974 Chevrolet Passenger Car Service Manual has been revised.
The revised procedure is as follows:
Corvette Speaker (Left Side)
Replacement
  1. Disconnect battery ground cable.
  2. Loosen windshield top garnish molding and remove windshield left side and right side garnish moldings.
  3. Remove right side dash pad.
  4. Remove one screw from instrument panel reinforcement and one screw from center console.
  5. Lift up on instrument panel top pad and disconnect speaker connection.
  6. Remove instrument panel.
  7. Remove screws securing speaker to underside of instrument panel pad and then remove speaker.
  8. To reinstall, Reverse Steps 1-7.
    CAUTION: Always attach speaker connection before applying power to radio.
  9. Check speaker operation.
Corvette Speaker (Right Side)
Replacement
  2. Remove three upper screws and two outer screws securing right dash pad.  Pull dash pad out slightly to expose speaker and speaker connector.
  3. Disconnect speaker connector.
  4. Remove four nuts on underside of instrument panel pad securing speaker and remove speaker.
  5. To reinstall, Reverse Steps 1-4.
    CAUTION: Always attach speaker connector before applying power to radio.
  6. Check speaker operation.
Article ID: 695
Created: August 1, 2014
Last Updated: August 1, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-news-removal-of-corvette-front-speakers-695.html
