Subject: BUZZING NOISE AT IDLE (INSTALL PRESSURE REGULATOR VALVE)
Model and Year:
1982-93 CAPRICE, CAMARO AND CORVETTE
1982-93 C/K, R/V, S/T, M/L AND G TRUCKS WITH 4L60 AUTOMATIC TRANSMISSION
Transmission Applications: 1982-1993 HYDRA-MATIC 4L60 (MD8)
Transmission Models: All
Vehicle Applications: B, D, F, Y - Cars C/K, R/V, S/T - Trucks G, M, L - Vans
Bulletin Number: 93-29-7A
CONDITION:
Some 1982-1993 vehicles equipped with a HYDRA-MATIC 4L60 transmission may have a buzzing noise coming from the transmission when the vehicle is at idle. The buzzing noise may be noticed more when the vehicle is in reverse at idle.
CAUSE:
The buzzing noise may be a result of pressure regulator valve oscillating due to oll pressure instability at lower idle RPM.
CORRECTION:
A new pressure regulator valve (III. 218) has been made which will improve the oil pressure stability at lower RPM.
SERVICE PARTS INFORMATION:
Description Part Number
Valve, Pressure Regulator (III. 218) 8684048
Article ID: 698
Created: August 1, 2014
Last Updated: August 1, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1993-corvette-service-bulletin-buzzing-noise-at-idle-698.html
