Subject: LOSS OF FRONT PUMP PRIME 350C TRANSMISSIONS
Model and Year: Early 1981 Corvettes
Bulletin Number: 81-T-38
SOME 1981 CORVETTES AND CAMAROS WITH 350C (MX3) AUTOMATIC TRANSMISSIONS MAY EXPERIENCE A MOMENTARY DELAY IN DRIVE RESULTING FROM LOSS OF FRONT PUMP PRIME. SINCE THIS DELAY CAN ALSO BE CAUSED BY A LOW FLUID LEVEL, THE OIL FILL MUST BE VERIFIED BEFORE ATTEMPTING ANY CORRECTIVE ACTION. IF THE TRANSMISSION HAS SUFFICIENT OIL AND THE CONDITION PERSISTS, PICK UP SCREEN P/N 6258504 SHOULD BE INSTALLED. THIS PART IS CURRENTLY IN SERVICE AS IT WAS USED IN 1980 TRANSMISSIONS. THE CHANGE WAS EFFECTIVE IN PRODUCTION ON 2-17-81 WITH TRANSMISSION DATE STAMP 157.
Article ID: 703
Created: August 1, 2014
Last Updated: August 1, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-loss-of-front-pump-prime-350c-transmissions-703.html
