Subject: Positraction Chatter
Model and Year: NA
Bulletin Number: 78-T-5, Section IV
Date: Jan., 1978
In some cases after extended expressway driving in warm ambients, a slip stick condition (chatter) occurs in the clutch plates of positraction axles during tight turns. Rubbing or moaning noises may accompany the chatter noise. Chattering conditions may be corrected by flushing the rear axle per the following procedure. If chatter recurs at a later mileage, add additive only.
NOTE: If it is not possible to perform Step #7, owner should be advised that it will require a minimum of 25 miles of normal driving to thoroughly work new lubricant into the clutch pack.
Article ID: 709
Created: August 2, 2014
Last Updated: August 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-positraction-chatter-709.html
