Subject: BRAKE ROTOR REFINISH PARTS ORDERING INFORMATION
Model and Year: 1981-90 ALL PASSENGER CARS AND TRUCKS
Bulletin Number: 90-293-5 - (06/22/1990)
Comments have been received of poor brake rotor finish and/or hard brake pedal feel after refinishing brake rotors using the On-Vehicle Brake Lathe (VGB 320/366, Kent-Moore 38-070400) sold through GM Dealer Equipment program.
CAUSE:
This condition results from using non-original cutting tips. Only original equipment replacement tips should be used.
CORRECTION:
When replacing the original cutting tips for an On-Vehicle Brake Lathe, use only replacement tips ordered from Kent-Moore Tool and Equipment Division. The replacement cutting tips can be ordered from Kent-Moore (1-800-GM-TOOLS) as follows:
Part Number: J-37704-13 Cutting Tips (Box of Ten)
We believe this source and their equipment to be reliable. There may be additional manufacturers of such equipment. General Motors does not endorse, indicate any preference for or assume any responsibility for the products or equipment from this firm or for any such items which may be available from other sources.
Article ID: 710
Created: August 2, 2014
Last Updated: August 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-brake-rotor-refinish-parts-ordering-information-710.html
