Subject: Enamel Paint Pilot Program
Model and Year: 1980 Corvette
Bulletin Number: 80-I-68, Section I
Date: July, 1980
In anticipation of the 1981 1/2 model year plant start-up at GMAD Bowling Green in June, 1981, a paint pilot program has been initiated at St. Louis to evaluate production application of each color released.
All pilot vehicles (approximately 80), as well as all future Bowling Green vehicles, will be finished with a two-tone acrylic enamel, as show on the following chart (St. Louis regular production will remain lacquer):
UPPER | LOWER | |||||
Color | G.M. Code | Fisher Code | Color | G.M. Code | Fisher Code | |
Autumn Red Met | E80 | WAEA 7411 | Dark Claret Met | E98 | WAEA 7421 | |
Silver Met | E33 | WAEA 7410 | Dark Blue Met | E38 | WAEA 7496 | |
Silver Met | E33 | WAEA 7410 | Charcoal Met | E39 | WAEA 7420 | |
Beige | E50 | WAEA 7498 | Dark Bronze | E74 | WAEA 7412 |
These special "E" paint codes will be stamped on the body I.D. plate.
This acrylic enamel color topcoat is a thermosetting material used to provide a durable, attractive, lustrous finish over the exterior surfaces of the vehicle. In addition, all metallic colors will have a "clear coat" applied to them which will provide the most lustrous and damage resistant finish available in the automotive industry. The front and rear bumper covers, or facias, will also be base coat/clear coat but will be a type of flexible paint as is currently used.
The base coat/clear coat system can be repaired with materials such as Dupont 380S, Ditzler DCA 468, or equivalent. Refinish colors may not be available until 1981. Contact the appropriate Zone Office to obtain color coat paint.
The repair should cover either the complete panel or to a feature line that provides an acceptable breakpoint. Spot repairing enamel with lacquer is not acceptable.
Recommended Procedure (Follow manufacturer’s label directions for reduction, application, and drying time.)
Chevrolet Motor Division
General Motors Corporation
Article ID: 712
Created: August 2, 2014
Last Updated: August 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-enamel-paint-pilot-program-712.html
