Subject: Heater Hose Clamp Interference with A/C Evaporator Inlet Pipe
Model and Year: 1976 Corvette with A/C
Bulletin Number: 76-T-43, Section Ia
Date: Nov. 1976
On some 1976 Corvettes, the heater hose clamp screw may rub against the evaporator inlet refrigeration pipe. This condition could cause a hole being worn through the evaporator pipe resulting in a loss of freon. For 1977 production models, this condition has been corrected by lengthening the heater hose.
1976 Corvettes, when serviced, should be checked for this condition. If interference is evident, the following changes should be made:
Recommended time for correction .3 hours.
Chevrolet Motor Division
General Motors Corporation
Article ID: 720
Created: August 2, 2014
Last Updated: August 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-service-bulletin-heater-hose-clamp-interference-with-a-c-evaporator-inlet-pipe-720.html
