On 1990 to 1996 Corvettes equipped with RPO C68 (electronic climate control), it is possible to read the HVAC system diagnostic codes from the climate control panel on the dashboard.
Note: If you see a "-" next to a parameter value (example: "-105"), you must add "100" to that value to obtain the correct value for that parameter. Therefore, the correct reading would be 205 for this example.
Parameter | Description | Values |
0 | System Faults (one of these will be set if your air conditioning controls have an LED flashing) |
00=No Faults 01= Temp Door Motor Circuit Fault 02= Temp Door Motor Circuit Fault 03 = Ambient Sensor Open 04 = Ambient Sensor Short 05 = In-Vehicle Temp Sensor Open 06 = In-Vehicle Temp Sensor Short 07 = Solar Load Sensor Open 08 = Solar Load Sensor Short 09 = Low Freon Detected 10 = UART Failure |
1 | Temp Setting | 60F to 90F |
2 | In-Car Temp Sensor | 10 = HOT -130 = 230 = COLD |
3 | Outside Temp Sensor | 10 = HOT -130 = 230 = COLD |
4 | Sun Load Sensor | Max light Max Dark L98 38 183 LT5 115 -110 = 210 |
5 | Ignition System Voltage | 0 = 9 Volts -155 = 255 = 16 V |
6 | Engine Speed (RPM divided by 25) | |
7 | Vehicle Speed | |
9 | A/C System Mode | 00 = OFF 01 = Re-Circulation 02 = A/C 03 = Bi-Level 04 = Heater 06 = Defrost 07 = Vent 10 = Manual Re-Circulation |
10 | Blower PWM | 0 = 0 Volts 128 = 14 Volts |
11 | Program Number | 00 = COLD -155 = 255 = HOT |
12 | Mix Number | -155 = 255 = COLD 00 = COLD |
16 | Coolant Temperature In degrees C | |
17 | Solar Correction | 114 = Max light 128 = max dark |
30 | Stored Full Hot Value | 0 to 50 |
31 | Temp Door Travel Range | 100 to 200 |
34 | Temp Door Position Requested | 00=Full HOT -153=253=Full COLD |
35 | Compressor On Time | 0.1 second increments |
36 | Number Of Times Below Critical Time | |
37 | Software Version Number |
Article ID: 723
Created: August 2, 2014
Last Updated: August 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-hvac-diagnostic-codes-723.html
