CHEVROLET CORVETTE PACE CAR
The Chevrolet Corvette Pace car decal package is designed for quick positioning and ease of application.Observance of a few simple pointers will greatly facilitate application.
GENERAL INSTRUCTIONS
1.Use experienced decal installers from your own staff or a commercial installer.
2.Air and surface temperature must be maintained between 68 and 104 degrees for proper installation.
3.Make sure the vehicle surface is properly cleaned in areas where the decals are to be applied with a suitable solvent such as a 1 to 1 mix of isopropyl alcohol and water.
4.Based on the experience of your installation team, the wet or dry method of application may be used (see special instructions below for wet application). WET METHOD RECOMMENDED.
CONTENTS
LH & RH Winged Wheel Logos
LH & RH Upper Door Lettering
LH & RH Lower Door Lettering
1 Plastic Application Squeegee
APPLICATION INSTRUCTIONS
Be sure to put driver’s side decals on the driver’s side of the car and passenger side decals on the passenger side of the car.
FRONT FENDER LOGO
DOOR UPPER DECALS
1 .Locate the door upper lettering to the door so that the locator rests on the body side molding and the front edge is flush with the front fender/door opening.
Following steps 2, 3, 4 and 5 as indicated for the front fender decals.
DOOR LOWER DECALS
Follow steps 3, 4 and 5 as indicated for the front fender decals.
After all decals are applied, go back and inspect for air bubbles or areas not fully pressed down.Carefully re-squeegee missed areas, pin prick and squeegee out air bubbles where necessary.
WET METHOD RECOMMENDED APPLICATION METHOD
This method is designed to facilitate the application of large or hard to handle parts.It also minimizes the chances of pre-adhesion prior to proper location being achieved.The wet method is recommended in all cases where the decal is being applied in direct sunlight, due to the overheating of the body surface.
For unusual application circumstances, where problems might arise, please write or phone:
KAY SCREEN PRINTING, INC.
1614 Clay Street, Detroit, Michigan 48211 – 313/872-4048
Article ID: 74
Created: July 4, 2014
Last Updated: July 4, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-pace-car-decal-installation-74.html
