Subject: Gear Block-Out and High Shifting Effort
Model and Year: 1963 1000 Series and Corvette with Muncie 4-Speed Transmission
Number: DR #611, Section VII
Date: August 7, 1963
Gear block-out and high shifting effort on Chevrolet Muncie built transmissions may be due to one or more of the following problems:
If difficult shifting is encountered in transmissions built prior to May 31, 1963, transmission number PO-531, the problem may be corrected by replacing the synchronizers and sleeves with Part No. 3850930 Synchronizer Unit, and inspecting the gear cones for bronze metal pick-up. if metal pickup exists, the parts involved should also be replaced.
Beginning with transmission number PO-531, the new synchronizer units and polished gear cones entered production.
PARTS DATA
Part No: 3850930
No. Req: 1
Description: Synchoizer Unit
Article ID: 742
Created: August 2, 2014
Last Updated: August 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-gear-block-out-and-high-shifting-effort-742.html
