Subject: Lubrication of Rear Wheel Inner Bearings - Corvette Models
Model and Year: 1963 - 1971 Corvettes
Date: November, 1972, Volume #44, Issue #11
Pages: 5
A new higher load capacity lubricant Shell EP-B2 P/N 9985038 was released in February 1972, for use in production. In conjunction with the production lubricant change, Engineering is recommending the following lubrication procedure for servicing all Corvette inner rear wheel bearings:
In the case of a new vehicle, the inner rear wheel bearings should be lubricated after 12,000 miles and every 24,000 miles thereafter. On past model vehicles a 24,000 mile interval is recommended.
The method for lubricating the bearings incorporates a new lubricator J-23388, Figure 2 which attaches to the rear wheel spindle after disassembly of the axle drive shaft and axle shaft flange from the spindle. The lubricator is installed over the spindle shaft and is secured flush to the bearing seal utilizing the existing spindle nut. The nut should be torqued sufficiently to seat the tool on the seal surface, as over torquing could damage the tool and or the bearing seal. (Fig. 3).
Fig. 2 - Bearing Lubricator J-24488
We must emphasize the importance of using only the recommended lubricant. In order to insure this, plus insure the correct quantity of this lube, we recommend the following procedure:
Article ID: 749
Created: August 2, 2014
Last Updated: August 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1971-corvette-service-news-lubrication-of-rear-wheel-inner-bearings-749.html
