Subject: SIPHON BREAKER PLATE UNIT #7014900 FUEL INJECTION
Model and Year:1958 PASSENGER CARS AND CORVETTES
Bulletin Number: TSB #565, Section VIm
Date: October 14, 1958
Improper seating of leakage past the spill plunger of 1958 Fuel Injection unit, part #7014900, may result in fuel being siphoned from the fuel bowl into one or more cylinders where the inlet valve happens to be open. The resulting hydrostatic lock can cause bent connecting rods and eventual connecting rod breakage. The condition occurs when the engine is re-started after being shut off for several hours. "Stalling" of the starting motor during engine re-starting might be an indication of fuel siphoning into the cylinders.
To overcome this problem, a Siphon Breaker Plate Kit, - part #7017143, has been released for service and is available in limited quantities for installation on #7014900 Fuel Injection units where it is suspected hydrostatic lock problems exist. Future production #7014900 Fuel Injection units will also incorporate this feature.
PARTS DATA
Part #: 7017143*
Description: Siphon Breaker Kit
Kit consists of -
7017314 Siphon Breaker Plate Assembly
7014927 3/16" Diameter Tube Elbow
7014461 Rubber Coupling
7014104 Pump Gasket
7006119 10-32 x 15/16 Screw (4)
7010422 10-32 x 3/4 Screw
* Unpublished number - order through Central Office P & A Dept.
INSTALLATION INSTRUCTIONS
Reference is made to Section V, Manual TP-5, 1958 CHEVROLET CARBURETION AND FUEL INJECTION: -
Flat Rate Time - .7 hour
Article ID: 766
Created: August 3, 2014
Last Updated: August 3, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-siphon-breaker-plate-unit-7014900-fuel-injection-766.html
