Subject: Automatic Choke Piston Inoperative Due to Carbon Deposits
Model and Year: 1957 - 265 & 283 CU. IN. V-8 Engines
Bulletin Number: DR #278, Section VI
Date: April 29, 1957
A new more durable Exhaust Manifold Choke Heat Tube has been released for production and service to provide a tube more resistant to heat.
In instances where the Automatic Choke Piston becomes inoperative due to carbon deposits, the Exhaust manifold Choke Heat Tube should be checked for leaks or damage.
INSPECTION
Remove Carburetor Choke Pipe Assembly and shine a light into the lower end of choke tube to see if carbon deposits are visible from upper end.
REMOVAL
Leaking or damaged tubes should be removed by driving tube out with a 5/16" diameter drift from the top of manifold. In some cases where the tube has become badly rusted or corroded in place, it may be necessary to remove the manifold from the engine to facilitate replacement.
Care must be taken not to elongate holes in manifold.
INSTALLATION
New tubes should be replaced from the bottom of manifold by driving until upper end of tube is flush with manifold and then staked securely in two places at bottom end.
PARTS DATA
Number Required | Description | Part No. | |
Old | 1 | Exhaust Manifold Choke Heat Tube | 3739717 |
New | 1 | Exhaust Manifold Choke Heat Tube | 3747292 |
ELH:kv
Article ID: 768
Created: August 3, 2014
Last Updated: August 3, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html
