Model Year: 1957
Subject: Fitting Hard Top on Corvettes
Source: Denver Zone 10 Letter
Bulletin Number: DZ-57
S&M-12
SMD-57-10
Date: February 26, 1957
Some field reports have been received where the dowel pins in the hard top would not line up with either the holes in the windshield upper molding or the holes in the molding in the deck area. Generally the hard tops are not too long but the distance between the two points on the body is too short.
The correct center to center distance between the hole in molding on the deck area and the windshield upper frame is approximately 31-5/8".
If this dimension is short any one or all of the following methods of correction may be used:
This is for your information.
Article ID: 794
Created: August 3, 2014
Last Updated: August 3, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-zone-letter-fitting-hard-top-on-corvettes-794.html
