by Lars Grimsrud
©2010 Lars Grimsrud.
This article may not be published or distributed without the written permission of the author
Rev. B 1-2-10
This tech paper will discuss the replacement of the front brake pads and rotors on the C-4 Corvettes. This paper deals specifically with the ’84 - ’87 model years, and applies generally to the ’88 through ’96 models. The rear brakes use the same process, so you can use this procedure as a guide for the rear, as well.
See attachment below:
Article ID: 86
Created: July 4, 2014
Last Updated: July 4, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html
