Subject: Corvette Disc Brakes Service Procedures Revised
Model and Year: 1965 Corvette
Page Number: 3
Date: October 1964, Volume 36, Issue Number 9
SHOE REPLACEMENT
When the brake shoe pads are replaced, it is necessary to first remove fluid from the master cylinder reservoir to avoid spillage when moving the caliper pistons. Removal of all the fluid in the reservoir can allow air to enter the master cylinder during the shoe replacement time if the pistons move toward the disc and, therefore, a bleeding operation would be required. To avoid this, remove only about 2/3 of the fluid in the master cylinder reservoir.
BLEEDING PROCEDURE
The operation of bleeding the disc brake hydraulic system is more involved than that required for the conventional shoe and drum type brake.
Either the pressure method or manual method can be used to bleed the disc brake system. The following procedure is recommended for each method and is adaptable to either the power (split) or manual (single) brake system.
PRESSURE METHOD
MANUAL METHOD
The same basic procedure should be utilized for this method as that used for the pressure method. The only difference being that pressure is supplied manually by pumping the brake pedal and applying a constant, moderate pressure while the bleeder valve is opened.
NOTE: On manual brakes, to insure that outside air is not sucked back into the hydraulic system, the bleeder valve should be closed before the brake pedal reaches the floor.
SPLIT BRAKE SYSTEM DIAGNOSIS
To aid Field personnel in determining if both front and rear brakes of the split (Power brake) system are operating properly, this short explanation of the operation is provided. The split system consists basically of two separate brake systems. When a failure is encountered on either, the other is adequate to stop the vehicle. If one system is not functioning, it is normal for the brake pedal lash and pedal effort to substantially increase. This occurs because of the design of the master cylinder which incorporates an actuating piston for each system. When one of the systems loses fluid and takes in air, its piston will bottom against the piston of the functioning system. This is felt at the brake pedal by an apparent lack of brakes for most of the brake travel and then, when the pistons are bottomed against one another, an extremely hard pedal. If a vehicle displays these symptoms, it is a good indication that one of the systems contains air. To determine which system is at fault, the car can be driven and braked hard enough to skid the wheels. The wheels that lock are functioning properly.
Article ID: 877
Created: September 2, 2014
Last Updated: September 2, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-corvette-disc-brakes-service-procedures-revised-877.html
