Problems I have Seen with Commercially Rebuilt Q-Jets
by Lars Grimsrud
©2010 Lars Grimsrud.
This article may not be published or distributed without the written permission of the author
Rev. D 10-2-10
As the Q-Jet carbs keep getting older, fewer and fewer are original carbs that have not been tampered with or altered. Rebuilding a Q-Jet is becoming a significant problem for the novice, because the carbs cannot be simply bolted together the way they came apart: The carbs have been altered, and these alterations must be identified and corrected before the carb will run as it was designed to do.
See attachment below:
Article ID: 88
Created: July 4, 2014
Last Updated: July 4, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-problems-i-have-seen-with-commercially-rebuilt-q-jets-88.html
