Subject: Repairing 1959 Passenger Car Direction Signals
Model and Year: 1959 Passenger Car
Page Number: 2-3
Date: December 1958, Volume 30, Issue Number 12
The most prevalent causes of 1959 passenger car direction signal malfunction are listed below, along with recommended correction for each.
Trouble:
Cancelling prong on steering wheel will not cancel the control lever.
Correction:
Remove steering wheel and bend cancelling prong on wheel assembly so that it stands perpendicular to the hub of the wheel. Do not "over bend" the prong as this will lead to an objectionable clicking sound when the turn signal lever is in the neutral position. Use care in replacing the wheel so that the prongs do not strike the steering shaft on assembly.
Trouble:
Turn signal will not cancel, usually only in one direction.
Correction:
Some early production cancelling pawls, Part No. 5950164, were distorted in manufacture, causing the pawl to remain clear of the cancelling prong on the steering wheel when moved into a turn position. Replacement of the pawl is the best fix.
Trouble:
Turn signal cancelling is erratic and may or may not cancel on turns in either direction.
Correction:
The condition is usually due to the actuating ring pivot pin becoming loose in the housing. The pin is a press fit in the housing and if it loosens, the actuating ring is free to move out of the path of the cancelling cam prongs. If the pin is loose in the housing, it should be removed and the serrations raised slightly. This may be done by striking the serrations several times using a light hammer and small chisel. The pin should then be pressed into the housing to a depth that locates the washer shoulder on the pin 1/22" above the top surface of the actuating ring.
Trouble:
Horn blows on turns while direction signals are operating.
Correction:
This could be the result of interference between a turn signal cancelling pawl and the horn connector assembly (spring loaded horn contact), which would ground the horn circuit. Pawl interference is probably caused by the actuating ring pivot pin either being loose, or pressed too shallow in the signal housing - correction explained earlier. If pressing the pivot pin to specified depth does not stop horn blowing, it will be necessary to lightly grind the top of the offending pawl to obtain clearance.
Trouble:
Flashing and cancelling of lights is erratic.
Correction:
This condition usually results from the turn signal switch either being damaged or out of adjustment and can be eliminated by performing the checks and adjustments outlined below:
Article ID: 887
Created: September 11, 2014
Last Updated: September 11, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-repairing-1959-passenger-car-direction-signals-887.html
