Subject: Temperature Gauge Erratic During Normalizing Period
Model and Year: 1955 Passenger Cars
Bulletin No: DR-254
Section: XII CROSS REFERENCE VI
Date: July 13, 1956
To: All Chevrolet Dealers:
In cases where both erratic and high temperature readings are being encountered on 1956 Passenger Cars during the "warm-up" period, the condition may be reduced by the installation of a 10 ohm-5 watt WIRE WOUND resistance in series with the sender unit located in the cylinder block.
PROCEDURE
The procedure for installing this 10 ohm resistor most satisfactorily is as follows:
Practice or removing the radiator pressure caps to correct this condition should be discontinued, as this reduces the overall cooling efficiency of the unit.
E.L. Harrig
Article ID: 902
Created: September 18, 2014
Last Updated: September 18, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html
