Subject: Axle Lube Change
Model and Year: 1984 Corvette
Page Number: Page 1
Date: September/October 1983 - Volume 55 - Number 5
Due to the reduced size of the differential housing on the above models, it may be difficult to remove axle lubricant. Therefore, a reduced size hose diameter should be used on the suction gun to remove the lubricant. The reduced hose diameter will allow the hose to clear the head of the pinion gear allowing access to the bottom of the housing.
Article ID: 935
Created: October 5, 2014
Last Updated: October 5, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-news-axle-lube-change-935.html
