Subject: Instability Above 60 MPH
Model and Year: 1956 Corvettes (Serial Numbers Listed)
Bulletin No: DR #267
Section: III
Date: October 10, 1956
When an unstable condition exist above 60 MPH on 1956 Corvettes between Serial No. E56S 3175 and E56S 4156, the parts listed below should be installed:
PARTS DATA
Part | Required | Part No. |
Steering Idler and 3rd Arm Assembly | 1 | 3733215 |
Special Caster Shim (Round 1" Diameter) Install between idler arm bracket and crossmember to lower Idler Arm.
2 | 3733479 |
Special Shim (Tapered)
2 | 3733477 |
Bolt 1-1/4" long | 6 | 181639 |
Wheel Alignment (Revised)
All of the above applies to the 1957 Corvette.
Article ID: 962
Created: October 19, 2014
Last Updated: October 19, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-instability-above-60-mph-962.html
