Subject: Spark Plug Fouling - Idle Adjustment
Model and Year: 1956 Corvette - Dual 4-Barrel - Carter Carburetor
Bulletin No: DR #258
Section: VI
Date: August 30, 1956
In cases where Spark Plugs are wet fouling on V-8 Engines used in 1956 Corvettes with dual 4-barrel carburetors being operated in Metropolitan Areas which put considerable limitation on their top speed, it may be necessary to install AC-46 Plugs to correct this condition.
AC-44 Plugs are to be furnished in production.
Range of plug should be tailored to the owner’s requirements:
AC-44 Extreme High Speed Driving
AC-44 Medium High Speed Driving
AC-45 City Driving and Normal Operation
AC-46 Metropolitan City Driving Under Heavy Traffic Conditions
IDLE ADJUSTMENT - CARTER DUAL 4-BARREL
To obtain a consistent idle speed setting on V-8 Engines equipped with Carter 4-Barrel Carburetors with regular or racing camshaft, proceed as follows:
Engine Number Suffix -
GH Regular Camshaft
GU Racing Camshaft
Article ID: 975
Created: October 25, 2014
Last Updated: October 25, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html
