Subject: Paint Repair Without Repainting
Model and Year: 1984 - 1985 Corvette and 1985 Astro Van
Bulletin No: 85-47
Section: 10(I)
Date: Mar., 1985
May minor paint imperfections such as scratches, dirt, chemical spotting, sags, and orange peel can be repaired without repainting (see Figure 1.) If an imperfection can be sanded out before reaching the colorcoat on vehicles having a clearcoat, there is no need to repaint.
The basic repair procedure involves sanding, compounding and polishing. The possibility of scratches in the finished repair can be avoided by sanding with a 1200 to 1500 micro fine paper such as 3M 02022, 02023 or equivalent and using a medium to find compound.
Notice: European "P 1200" is much coarser and, therefore, not equivalent to US 1200.
In many instances repairs can be made by compounding and polishing, and should be attempted prior to any sanding.
Compounding and Polishing
When making repairs, the following materials or equivalent are recommended.
Color Sanding Paper | 3M Wet or Dry 1200 Micro Fine |
#02022 |
Color Sanding Paper | 3M Wet or Dry 1500 Micro Fine |
#02023 |
Sponge Pad | 3M Imperial Wet or Dry Sponge Pad |
#05530 |
Compound | 3M Super Duty Liquid Compound |
#05955 |
Polish | 3M Final Glaze | #05988 |
Buffing Pad | 3M Superbuff Pad | #05701 |
Polishing Pad | 3M Super Buffing Pad | #05705 |
NOTICE: 3M micro fine paper is currently in limited supply and may not be readily available until approximately April 1, 1985.
"We believe this source and their material to be reliable. There may be additional manufacturers of such material. General Motors does not endorse, indicate any preference for or assume any responsibility for the products or equipment from these firms or for any such items which may be available from other sources."
Article ID: 996
Created: November 3, 2014
Last Updated: November 3, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-paint-repair-without-repainting-996.html
