Home C8 Corvette News Add an Additional 25 HP to your C8 Corvette with the Lingenfelter Carbon Fiber Intake Manifold
Lingenfelter Performance Engineering Launches Performance Design Carbon pTR Intake Manifold for C8 LT2 Corvettes
7K views
Lingenfelter Performance Engineering Launches Performance Design pTR Carbon Fiber Intake Manifold System for C8 LT2 Corvettes
After a year of intense development, rigorous testing, and proven validation, the Performance Design Carbon pTR Intake Manifold is ready for the street as well as the track and available exclusively through Lingenfelter Performance Engineering.
Producing an additional 25 horsepower at the rear wheels on average when used with the Lingenfelter 95 mm Throttle Body, the Performance Design Carbon pTR Intake Manifold takes stock C8 LT2 Corvettes to the next level with style and performance. It features a great-looking 5-layer carbon fiber upper and a durable heat-resistant glass-reinforced nylon lower while embracing lightweight tunnel ram architecture.
Innovative engineering allows for complete ECM integration using the factory connectors, and there is no calibration required.
The Performance Design Carbon pTR Intake Manifold is an all-inclusive, technically advanced system with absolutely everything, from the pressure tested Performance Design Carbon pTR Intake Manifold to the high-performance Lingenfelter 95 mm Throttle Body (if required). In addition, this advanced system includes the appropriate couplers, hoses, harnesses, gaskets, fasteners, and connectors which were specifically designed to work with the factory-installed connections and fittings on all C8 LT2 Corvettes. (Does not fit convertibles)
Lingenfelter Performance Engineering Launches Performance Design pTR Carbon Fiber Intake Manifold System for C8 LT2 CorvettesFor more information or to schedule an install, give us a call at one of our Lingenfelter Performance Engineering Build Centers or send an email to sales@lingenfelter.com.
1557 Winchester Rd, Decatur, IN 46733
47451 Avante Dr, Wixom, MI 48393
For more information, Call (260) 724-2552 go to
https://www.lingenfelter.com/performance-design-ptr-carbon-fiber-c8-lt2-corvette-intake-manifold
