Corvettes have had headlights under plastic lenses starting with the C6. A problem with plastic headlights can be that, over time, plastics made from polycarbonate may turn a yellowish-brown and develop a rough or crusty surface. Not only is that ugly, but it also reduces the brightness of the headlights.
The more your Corvette’s headlight lenses are exposed to natural light, the more they’ll tend to turn yellowish-brown. If your car spends most of its life in a garage, under a cover or has WeatherTech LampGard headlight protectors installed, then you’ll never have trouble with hazed headlights. Otherwise, over time, your headlight lenses will get ugly.
Since plastic headlights and headlight lenses have been around for decades, the aftermarket has responded to the UV degradation problem with headlight repair or restoration kits. We’ve looked at some and the one we prefer is Sylvania’s “Headlight Restoration Kit”. This product is available from a wide variety of sources and, not only did it work well in our testing, it is highly-rated by Consumer Reports.
First, is to apply a “surface activator/cleaner” which you leave on the lens for a short period then wash off. The second step is sanding and polishing. You will wet-sand the headlight lens with fine (400-grit), then extra fine (1000- and 2000-grit) sand paper. A lot of pressure is unnecessary. We found using a small, rectangular sponge as a “sanding block” made the job a little easier.
