Home Product ReviewsEngine and Drivetrain [Product Review] Weapon-X 180° Thermostat for C7 Corvette
by AvatarHib Halverson
9.8K views
Weapon-X 180° Thermostat for 2019 Corvette ZR1
One of the first changes we made to the CAC’s ’19 ZR1 was replacing the stock, 194° thermostat with a Weapon-X 180° ‘stat (PN SD180LT1). The goal with that change was lower engine coolant temperature (ECT) during highway driving as well as lower ECT during aggressive driving at higher speeds.
On a C7, regardless of which engine is in the car, LT1, LT4 or LT5, a thermostat change is pretty easy. You drain the radiator–in the case of the ZR1, drain just the main radiator. Remove the duct–properly termed the “upper air baffle extension”–that runs from the back of the radiator to the hood vent. Disconnect the upper radiator hose and the steam hose that runs between the thermostat housing and a tee in the surge-tank-to-radiator pipe. Then remove the three housing bolts and pull out the ‘stat.
The housing and the thermostat assembly are all one piece. The thermostat “core” is part of this assembly. Grasp the housing in one hand and then push the other end of the assembly against spring pressure and twist the bottom metal cap. The cap will come off. The springs will come out. Then, the thermostat core can be extracted from the housing.
Install the Weapon-X 180 in place of the OE thermostat. Put the big spring pack in place. Then push, twist and lock the bottom cap in place. Put the thermostat assembly back in the front of the engine, install and hand tighten the three housing bolts. Torque each bolt to 10-Newton-Meters or 89-inch-pounds. Finally, reconnect hoses, reinstall clamps and screw the baffle extension back in place.
Now you’re going to refill the cooling system with whatever water/antifreeze coolant mix you choose. Close the radiator drain then fill the system until the coolant level gets to the bottom of the surge tank fill neck. Start the engine and idle it for about four minutes while adding additional coolant to keep the coolant at that level. After four minutes and with the coolant level at the bottom of the filler neck, run the engine at about 2000-RPM for a couple of minutes, then let the engine idle and check the coolant level again. Add coolant as necessary then shut the engine off. Let the engine cool to ambient temperature–usually I let the car sit over night. Check the coolant level and adjust as necessary.
I’ve had Weapon-X’s 180 ‘stat in my LT5 for a couple of months now. There were no problems installing it. No problems with leaks and on the highway the temperature is 180-183°. I have not run the car on a chassis dyno with the 180 installed, yet, but in driving where I’m running the engine harder than I would just cruising on the highway, the ECTa is lower than it was in similar situation with the stock thermostat. The price was 60 bucks which is a lot less expensive that some alternatives which consist of the whole assembly rather than just the thermostat core by itself. The Weapon-X 180 is also 10 bucks less than Katech’s thermostat cores.
Weapon-X also sells a 160° version of this thermostat.  For more information, see the Weapon-X web site.
1 comment
Avatar
uncle vito April 4, 2021 - 3:49 pm
I would keep the stock thermostat. GM knows much more about cars than Weapon-x. In fact, I will bet Weapon-x gave Hib a free stat inexchange for this positive article.
Reply
