Below is a listing of general specifications for the 1953 Corvette including, engine, chassis, suspension and more.
| Dimensions | |
| Wheelbase | 102.0 in |
| Track Frt/Rear (in) | 57.0/59.0 |
| Length | 167.0 in |
| Width | 72.2 in |
| Height | 52.1 in |
| Frontal Area | NA |
| Ground Clearance | NA |
| Curb Weight | 2850 lbs |
| Weight Dist. F/R (Engine) | 53/47 |
| Fuel Capacity | NA |
| Coolant Capacity | NA |
| Engine Specifications | |
| Bore | 3 9/16 in |
| Stroke | 3 15/16 in |
| Displacement | 235.5 ci |
| Compression Ratio | 8.0:1 |
| Horsepower | 150 bhp @ 4200 rpm |
| Torque | 223 lb-ft @ 2400 rpm |
| Redline | NA |
| Carburetion | 3x1 bbl |
| Oil Capacity | NA |
| Valvetrain | NA |
