Below is a listing of general specifications for the 1955 Corvette including, engine, chassis, suspension and more.
| Dimensions | |
| Wheelbase | 102.0 in |
| Track Frt/Rear (in) | 57.0/59.0 |
| Length | 167.0 in |
| Width | 72.24 in |
| Height | 51.25 in |
| Frontal Area | NA |
| Ground Clearance | 6.0 in. |
| Curb Weight | 2750 lbs |
| Weight Dist. F/R (Engine) | NA |
| Coolant Capacity | 17.75 |
| Fuel Capacity | 17.25 gal. |
| Engine Options & Specifications | ||
| 2934-6 | 2934-8 | |
| Type | OHV, inline-6 cylinder | OHV, 8 cylinder |
| Bore | 3.56 in. | 3.75 in. |
| Stroke | 3.94 in. | 3.0 in. |
| Displacement | 235.5 ci | 265 ci |
| Compression Ratio | 8.0:1 | 8.0:1 |
| Horsepower | 150 bhp @ 4200 rpm | 195 bhp @ 5000 rpm |
| Torque | 223 lb-ft @ 2400 rpm | NA |
| Redline | NA | NA |
| Carbueration | 3 sidedraft Carter Carbs. | Carter 4-bbl |
| Oil Capacity | NA | NA |
| Valvetrain | Hydraulic | Hydraulic |
| 0-60 mph | NA | 8.5 sec (Road & Track, March 1955) |
| 1/4 Mile | NA | 16.5/85 mph (Motor Life, Sept. 1955) |
