Menu Navigation
1960 Corvette Identification Numbers
VIN Tag Information
00867S100001 - 00867S110261
Digit Definition
1st Model year:  0 = 1960
2nd / 3rd Series:  08 = Corvette
4th/5th Body Style:  67 = 2-door convertible
6th Assembly Plant:  S = St. Louis, MO.
Last 6 digits Production Number starting with 100001 - 110261
Engine Suffix ID Numbers
CQ: 283ci, 230hp, (manual transmission)
CR: 283ci, 250hp, (manual transmission)
CS: 283ci, 290hp (manual transmission)
CT: 283ci, 245hp (manual transmission)
CU: 283ci, 270hp (manual transmission)
DG: 283ci, 230hp, (automatic transmission)
DJ: 283ci, 245hp (automatic transmission)
Block ID Numbers
3756519: All Engines
Head ID Numbers
3774692: All Engines
Carburetor ID Numbers
Carter 2613S #3741089: 283ci, 270hp (front carburetor)
Carter 2614S #3741090: 283ci, 270hp (rear carburetor)
Carter 2626S #3744002: 283ci, 245hp (front carburetor)
Carter 2627S #3744004: 283ci, 245hp (rear carburetor)
Carter 2818S #3756676: 283ci, 230hp (first design)
Carter 3059S #3779178: 283ci, 230hp (second design)
Distributor ID Numbers
1110891: 283ci, 245hp, 270hp
1110914: 283ci, 290hp
1110915: 283ci, 250hp
1110946: 283ci, 230hp
Fuel Injection ID Numbers
Rochester 7017200: 283ci, 250hp
Rochester 7017250: 283ci, 290hp
Rochester 7017300: 283ci, 290hp
Rochester 7017310: 283ci, 250hp
Rochester 7017320: 283ci, 290hp
Generator ID Numbers
1102043: 283ci, 230hp, 245hp, 250hp, 270hp
1102173: 283ci, 290hp
