Menu Navigation
Below is a listing of general specifications for the 1969 Corvette including, engine, exhaust and more.
Engine Options & Specifications
  Base 350 ci L46 350 ci L36 427 ci L68 427 ci L71 427 ci L88 427 ci L89 427 ci
HP @ RPM 300 @ 4,800 350 @ 5,800 390 @ 5,400 400 @ 5,400 435 @ 5,800 435 @ 5,800 600 @ 5,800 *
Torque @ RPM 360 @ 3,400 360 @ 3,600 460 @ 3,600 460 @ 4,000 460 @ 4,000 550 @ 4,000 * 460 @ 4,000
Compression Ratio 10.25:1 11:1 10.25:1 10.25:1 11:1 12.5:1 NA
Carburetion 4 bbl Rochester 4 bbl Rochester 4 bbl Rochester 3 x 2bbl Holley 3 x 2bbl Holley 4 bbl Holley NA
Intake Manifold Cast Iron Cast Iron Aluminum Aluminum Aluminum Aluminum Aluminum
Valve Lifters Hydraulic Hydraulic Hydraulic Hydraulic Mechanical Mechanical Mechanical
Exhaust Dual, 2.0 in. Dual, 2.0 in. Dual, 2.0 in. Dual, 2.0 in. Dual 2.0 in. Dual 2.0 in. Dual 2.0 in.
Oil Capacity 5 qts w/ filter 5 qts w/ filter 6 qts w/ filter 6 qts w/ filter 6 qts w/ filter 6 qts w/ filter 6 qts w/ filter
Spark Plugs ACR 44 ACR 44 ACR 43N ACR 43N ACR 43N ACR 43XL NA
C3 Corvette Forum
